Use this procedure to view the Neighbor Discovery inspection statistics on a port or set of ports.
The following table defines parameters for the show ipv6 fhs statistics nd-inspection command.
Variable |
Value |
{slot/port[/sub-port][-slot/port[/sub-port]][,...][slot/all][all]} |
Identifies the
slot and port in one of the following formats:
